Your problem is you need to upgrade and enable the vBulletin actionset that came with vBCredits II Deluxe!
Leave it disabled, then import the new product-credits_vbulletin.xml that is in the XML folder from the zip you downloaded for Deluxe.
Afterwards, enable it and your displays will work That actionset runs the displays found in standard vbulletin - that is, 4/5ths of the ones currently available, including the postbit
