mrtung9x
I want to have 1 functions as :
Member will receive credits for each time they click thanked .
Some one help me create Event for mod thanks .
Thank you !!!
That action is not yet implemented, however it is on the shortlist for integrations once the paypal feature is implemented.
This action could be used like content merchants?
I mean: one user post a link or attachment that requires thanks to be seen, this user could specify that press thanks button would cost 50 (pr any other amount changeable by user) credits, so each user that press thanks button spent 50 credits wich will be added to original user bank account who posted the link or attachment
Hope this will be integrated.
Post Thank Hack Not working with VBcreditsII
This is supposed to be able to work with VDcreditsII.
However, after installation, I see no configuration options for actions.
i.e. I want users to get points when they are thanked, or when they thank someone else.
Hi there, is it possible you could point me to where you saw the claim that it is integrated with the Thanks mod?
To the best of my knowledge this feature has not been implemented yet - i'd like to correct any misinformation you may have seen
Darkwaltz4 will confirm the status of thanks mod integration in this thread once he see's it =)
Thanks for your help,
Cosmic
I think I got the impression by reading a blurb that referenced the flexibility of the vbcredits system and included a statement that it could be made to work with a variety of other plugins.
I may have also thought this after reading the details about the other vbcredits system in development. I'll refrain from posting name or URL. I'm sure that the dbtech sytem will quickly match any features of any other competition. I'm happy to see you released first.
vBCredits does indeed have an API to make it easier for other mods to hook in - we will be hoping to add integration with APTL when it goes gold, if Fillip H. has time to.
On a related note v2 of vBCredits should be out shortly, and hopefully there will be more opportunity for smaller integration updates as required after that ^.^
Deluxe version is possible to integrate with Post Thank You Hack
Hi, excuse me for my bad english,
i want know if is possible to integrate vBCredits with Post Thank you hack... I want assegnate (for expample) 5 point if an user receive a thanks....
I want paid for this feature if isn't not implemented...
Please help me... Thanks!
there was an integration for vbcredits which should still work with this one if you keep the default Credits currency. otherwise, a newer version hasnt been made yet
How to integrated post thank you hack and vbcredit 2 vbb4?
I used the addon " vbcredits with post thank you hack":
"This is an addon by Darkwaltz4 [blackwaltz4@msn.com] that allows credits to be gained when users receive thanks used by the Post Thank You Hack."
Everything works fine but when I delete a post, it gets error:
Database error in vBulletin 4.0.7:
Invalid SQL:
UPDATE user SET credits = credits + 0 WHERE userid =;
MySQL Error   : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '' at line 1
Error Number  : 1064
Attach file is addon I used.Any help?
Thanks for this plug-in... :) I need it :) But it's possible personalize it? i want donate 3 point and not 5 point... Thanks and excuse me for my bad english...
you are welcome :) it was made for vbb 3.x but it works with vbb4 except the error I've mentioned.
hope Darkwaltz4 will convert this mod to vbb 4 :)
yeah :) I'm using it now and it works :) but it's not really compatible with vbcredit II, I get DataBase error when I delete posts (note: physically remove not soft delete, it works fine with soft delete of post) that contain "user's thanks" :(
Legacy vBCredits II Deluxe
