If you're attempting to use the shoutbox in a location other than the predefined, you'll need to set the automatic display to disabled and fill in both the script and template fields.
And obviously if the template name is wrong, it'll not show up.
Can you be a bit more specific about what values you attempted to use?
I added the following
Shoutbox Deployment : index
Manually Display Shoutbox : FORUMHOME
Auto-Display Shoutbox : Disabled
Added {vb:raw vbshout} to FORUMHOME
Same here, just upgraded to 4.5.0 but it doesn't show up.
have these settings:
Active: Yes
Auto Display: Disabled
Shoutbox Deployment: index,vbulc
Manually Deploy Shoutbox: FORUMHOME,ulc
And added {vb:raw vbshout} to the templates FORUMHOME and ulc where I want the shoutbox to display.
