Nirjonadda
What Do You Mean by Admin Strikes and Login Strikes Viewer ? Please give me some more info about that, Also I have some bug on the logger , please check the ScreenShot.
Unknown language or User name:
User name not found:
User ID : 0 , Does vB have user id 0 ?
It will revert to displaying "user id: x" if the user has been deleted. If the record can't be looked up, it'll display 0 as a last resort.
What collation is the username column on the dbtech_vbsecurity_loginstrikes table set to? Is it the same as the rest of your database?
I'm sorry, I didn't understand what are you asking ?
Can you click "Structure" on that list and show me a screenshot of the resulting page?
Is that username column the same collation as your username column in the user table?
I have get datebase error via email.
Database error in vBulletin 4.2.2:
Invalid SQL:
SELECT username
FROM vbdbtech_vbsecurity_loginstrikes AS loginstrikes
ORDER BY username;
MySQL Error : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'FROM vbdbtech_vbsecurity_loginstrikes AS loginstrikes
ORDER BY username' at line 3
Error Number : 1064
Request Date : Sunday, February 9th 2014 @ 07:52:57 PM
Error Date : Sunday, February 9th 2014 @ 07:52:58 PM
Script : /admincp/vbsecurity.php?do=loginstrikes
Referrer : /admincp/index.php?do=nav
IP Address : 90.221.161.xx
Username : Nirjon
Classname : vB_Database_MySQLi
MySQL Version : 5.5.35-cll
Legacy vBSecurity
