mikez006
Starting on July 28th, new purchases for the auto-bump item no longer work. Old auto-bumps still work, but nothing purchased from July 28th.
The threads do not bump every x hrs as they should.
I think there might have been an update to my server that caused this problem.
Fillip I did not yet implement the fix for the Credit PIN problem I email you about, so that is not the cause.
This is the error I get when the auto-bump cron job runs: (im not sure why credits_vbulletin.php is used when the auto-bump cron is run)
PHP Warning: array_merge(): Argument #1 is not an array in ..../dbtech/credits/credits_vbulletin.php on line 622
Fatal User Error: Existing data passed is not an array
Called set_existing in ..../dbtech/vbshop_pro/items/autobump.php on line 169
Called autoBump in ..../dbtech/vbshop_pro/cron/autobump.php on line 68
Called include_once in ..../admin/cronadmin.php on line 116
in ..../includes/class_dm.php on line 265
#1 : vbstop() called in ..../includes/class_core.php on line 5815
#2 : vb_error_handler() called in on line
#3 : trigger_error() called in ..../includes/class_dm.php on line 265
#4 : vB_DataManager->set_existing() called in ..../dbtech/vbshop_pro/items/autobump.php on line 169
#5 : vBShop_Item_autobump->autoBump() called in ..../dbtech/vbshop_pro/cron/autobump.php on line 68
#6 : include_once(..../dbtech/vbshop_pro/cron/autobump.php) called in ..../admin/cronadmin.php on line 116
