This has to do with the fact that Auto-Idle is now also a per-usergroup setting which overrides the Admin Global setting.I turned on Auto Idle before. It seems to work fine.
However when I turned it off again, I am still showing up as idle even after a complete page refresh.
That's because the dropdown doesn't control the size of your shouts, as you might expect, but the font size of all shouts.Actually I think a lot of things are not able to be turned off. For example I also disabled the bb size code but it is still showing up in the shoutbox.
I'll remove the AdminCP option in the next version.
It's something only the user can see, though.
Webpage error details
User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0)
Timestamp: Fri, 5 Mar 2010 22:07:42 UTC
Message: Invalid argument.
Line: 269
Char: 4
Code: 0
URI: http://www.dragonbyte-tech.com/clientscript/dbtech/vbshout/vbshout.js?v=4110
