IcEWoLF
Unfortunately I am getting a 404 page with my edgecast cdn, I tried to purge cache but it seems it's not working at all :/
WebPagetest Test Details - Dulles : [url]www.47r-squad.com/forum.php - 07/10/12 03:55:39[/url]
Showing as: http://edge.47r-squad.com/clientscript/steamprofile/ajax/themes//style.css
Should be http://edge.47r-squad.com/clientscript/steamprofile/ajax/themes/steam/style.css
This happens only when the CDN is enabled, when I disable CDN then everything works and it shows the correct path.
With this said, I tried both EdgeCast CDN & MaxCDN, and both have the same result.
Not sure how the path somehow gets messed up :/
Can you please PM me with an AdminCP account? I recall there were some configuration issues with Origin before on another site but I'm not sure exactly what I did in the config to fix it :p
Due to the fact that you're using vBSEO's CDN, only 1 URL in total is CDNised by vB Optimise. All other urls are being usurped by vBSEO.
I was unable to find the URL you mentioned in the first post in the source of forum.php so I'm sadly unable to assist further :(
I am still unable to locate style.css in the display code either logged in or as a guest :(
Your CDN should have an Access Control feature somewhere that you can add your domain to.
There's no way to exclude the clientscript folder from the CDN, but it shouldn't be needed as other CDN providers allow you to configure access lists :)
Hi Fillip H., the CDN or the web host?
I was reading few things online and I am told that this would be done on the server end instead of CDN.
I honestly don't know, but I know that people who use MaxCDN with Origin Pull/Mirror don't have these issues.
