Editing a post with charge tags will properly load the charge tag content for editing if you use the Standard and Basic editors for the time being. I am looking into why it has stopped working for the new Enhanced editor.
Think this will do the trick:
step 1)
Find the plugin called "vBCredits II - Charge Content Strip" using the "bbcode_parse_complete" hook (this is an important distinction to find the right one, because there are 4 plugins using that title)
Replace and save the Plugin PHP Code with:
if (strtolower(get_class($this)) == 'vb_bbcodeparser_plaintext') $text = VBCREDITS::charge_strip_raw($text);
step 2)
Add a new plugin with vBCredits II deluxe as the product, "bbcode_create" as the hook location, "vBCredits II - Charge Content Load" as the title, 1 as the execution order, Yes for plugin is active
and this for Plugin PHP Code:
if (strtolower(get_class($this)) == 'vb_bbcodeparser_wysiwyg' AND $charge = $this->registry->options['credits_action_content_bbcode']) $this->unparsed_tags[] = $charge;
Save it, and you should be all set to edit charge content tags in all cases.
hello, when i go to advanced editing. the whole charge tag area disappeared. so it doesn't work. please test it before let us try it.
thank you very much
it works now.
thank you
I did test it, locally and here on dbtech - its working great.
Did you do the plugin edits I posted previously?
Charge tag problem (new ones)
how to set the administrator, moderators or special group to view charge content without paying?
1st: Right now it seems that everybody has to pay to view content, but if i don't select the group (administrator, moderators or special group) in the "Activity Amounts Configuration" - content area, there is no charge event, it won't even show the charge area.
2nd: when i edit threads, i got award again. do you know how to set up only award for new thread. not award for editing thread?
please help.
thank you
1) Currently no way to mark a usergroup for free content viewing, but those groups should have the ability to quick-edit posts and thus see the content that was being charged for (thanks to the patch I just helped you with)
2) That is by design - make sure you are setting a negation value in your event. It needs to recalculate itself by negating and reawarding should anything change like the length of the post or if it becomes soft deleted.
2: how to set up a negation value in event? and where to set up it?
please give detail information.
what is the post charge? i don't how how to get this one work. Post event.
thank you
Legacy vBCredits II Deluxe
