iadventure
Are you running vBSEO? If so, that's probably the issue. vBCMS had an issue prior to v4.2.0 with SEO rewrite not working with mods. The issue is fixed with the v3 Beta of vBSlider (if you are running vB4.2 or higher), but hasn't made it into the lite version yet.
With that said, if you do a search in dbtech/vbslider/actions/widget.php for content.php, and replace it with content (there should be 2 instances to fix), then you should be set. I'm currently away from my computer, otherwise I'd give you exact line numbers where it is located. If you want to wait, I can provide the change later tonight, but figured I'd provide a fix if you want to try it on your own.
If that doesn't fix the problem, let me know and I will look into it further.
Yeah, sorry about that. Wife ended up having other plans for me, plus I worked for 16.5hrs on my M-F job on Sat and Sun. Gotta love it...
I realized you are running the pro version, not the lite version, so this is posted in the wrong area. I'll get that moved (hopefully), but anyway, lets look at the issue.
On line 487, you should have the following:
$row['url'] 	= ($row['type'] == 'article' ? $vbulletin->options['bburl'] . '/content.php/' . $row['nodeid'] . '-' . $row['url'] : $row['url']);
Replace that with this:
$row['url'] 	= ($row['type'] == 'article') ? ((version_compare($vbulletin->versionnumber, '4.2.0' >= 0)) ? $row['url'] : $vbulletin->options['bburl'] . '/content.php/' . $row['nodeid'] . '-' . $row['url']) : $row['url'];
Let me know if that works for you.
Ok, I see you are running vB 4.1.10 and vBSEO, and I missed part of your working link above. Try the code below (in the same place as before) and let me know if it works.
$row['url'] 	= ($row['type'] == 'article') ? ((version_compare($vbulletin->versionnumber, '4.2.0' >= 0)) ? $row['url'] : $vbulletin->options['bburl'] . '/content/' . $row['nodeid'] . '-' . $row['url']) . '.html' : $row['url'];
I realized I missed something for the previous fix to work. Sorry about that. On or around line 282, find:
'url'				=> $rowarticle['url'],
and replace with:
'url'               => (version_compare($vbulletin->versionnumber, '4.2.0') >= 0 ? fetch_seo_url('vBCms', $rowarticle,null,'nodeid','title') : $rowarticle['url']),
Also replace the code previously mentioned in post #7. If that doesn't work, then I will need to get the access mentioned above so I can make changes to the file directly to sort out the problem.
Legacy vBSlider
