Bug Code Does Not Seperated
Nirjonadda
Code Does Not Seperated in dbtech\thanks\clientscript\thanks.js ? I need to add some code but impossibile read to find.
In Version 3.2.9 Code Is:
$.noConflict(true)(function($) {
    var ftd = $(document),
        lastClick = 0;
    thanksOptions.floodTime = parseInt(thanksOptions.floodTime);
    if (thanksOptions.vbversion > 3) {
        ftd.on('click', 'a[name=dbtech_thanks_downranked]', function(e) {
            e.preventDefault();
            var postid = $(this).attr('data-postid');
            _displayPost(postid);
    ftd.on('click', 'a[name=dbtech_thanks_button]', function() {
        if (thanksOptions.floodTime > 0) {
            var d = new Date();
            var timenow = parseInt(d.getTime() / 1000);
            if ((timenow - lastClick) < thanksOptions.floodTime) {
                alert(vbphrase['dbtech_thanks_must_wait_x_seconds'].replace('%time%', thanksOptions.floodTime).replace('%time2%', (timenow - lastClick)));
                return false;
            lastClick = timenow;
        if (typeof thanksOptions.thanksEntries[postid] == 'undefined') {
            thanksOptions.thanksEntries[postid] = {};
        thanksOptions.thanksEntries[postid][$(this).attr('data-button')] = parseInt(thanksOptions.thanksEntries[postid][$(this).attr('data-button')]) - 1;
        _colourPost(postid);
        var extraParams = {
            'securitytoken': SECURITYTOKEN,
            'do': 'ajax',
            'action': 'entry',
            'varname': $(this).attr('data-button'),
            'contenttype': thanksOptions.contenttype,
            'p': postid
        var type = 'POST';
        var jqxhr = $.ajax({
            type: type,
            url: 'thanks.php',
            data: (SESSIONURL ? SESSIONURL + '&' : '') + $.param(extraParams)
        }).done(function(data) {
            if ((extraParams['varname'] == 'thanks' || extraParams['varname'] == 'likes') && typeof(vFC_HT_JS) == "function")
            	 vFC_HT_JS.prototype.thanks_unhide(postid);
            var tagData = $(data),
                origData = data;
            data = {
                thanksEntries: {},
                colorOptions: {}
            var singleVals = ['entries', 'actions', 'error'];
            if (tagData.find('colorOption').length) {
                tagData.find('colorOption').each(function() {
                    var tagData2 = $(this);
                    if (typeof data.colorOptions[tagData2.attr('varname')] == 'undefined') {
                        data.colorOptions[tagData2.attr('varname')] = {};
                    data.colorOptions[tagData2.attr('varname')][tagData2.attr('numclicks')] = {
                        color: tagData2.text(),
                        settings: tagData2.attr('settings')
            if (tagData.find('thanksEntry').length) {
                tagData.find('thanksEntry').each(function() {
                    data.thanksEntries[$(this).text()] = $(this).attr('numclicks');
            for (var i in singleVals) {
                data[singleVals[i]] = '';
                if (tagData.find(singleVals[i]).length) {
                    data[singleVals[i]] = tagData.find(singleVals[i]).text();
                } else if (singleVals[i] != 'error') {
                    data['error'] = origData;
            if (data.error) {
                alert(data.error);
                console.error(timeStamp() + "AJAX Error: %s", data.error);
                return true;
            $('#dbtech_thanks_entries_' + postid).html(data.entries);
            $('#dbtech_thanks_actions_' + postid).html(data.actions);
            if (typeof data.thanksEntries != 'undefined') {
                thanksOptions.thanksEntries[postid] = data.thanksEntries;
                switch (thanksOptions.contenttype) {
                    case 'post':
                        break;
                    case 'blog':
                        break;
            if (data.colorOptions) {
                thanksOptions.colorOptions = data.colorOptions;
    if (thanksOptions.contenttype == 'post') {
        for (var postId in thanksOptions.thanksEntries) {
            _colourPost(postId);
    function _colourPost(postid) {
            return false;
        var highestThreshold = 0,
            highestObj;
        for (var varName in thanksOptions.colorOptions) {
            if (typeof thanksOptions.thanksEntries[postid][varName] == 'undefined') {
                continue;
            thanksOptions.thanksEntries[postid][varName] = parseInt(thanksOptions.thanksEntries[postid][varName]);
            for (var threshold in thanksOptions.colorOptions[varName]) {
                threshold = parseInt(threshold);
                if (thanksOptions.thanksEntries[postid][varName] >= threshold && threshold > highestThreshold) {
                    highestThreshold = threshold;
                    highestObj = thanksOptions.colorOptions[varName][threshold];
        if (thanksOptions.vbversion == 3) {
            $('#post' + postid + ' tbody td').each(function(index, element) {
                if ($(this).is('.alt1, .alt2')) {
                    $(this).addClass(function(index, currentClass) {
                        var exploded = currentClass.split(' ');
                        for (var i in exploded) {
                            if (exploded[i].toString().match(/\bthanks_highlight_/)) {
                                $(this).removeClass(exploded[i]);
                        return (highestThreshold > 0 ? 'thanks_highlight_' + highestObj['color'] : '');
        } else {
            $('#post_' + postid + ' .posthead,#post_' + postid + ' .postfoot .textcontrols,#post_' + postid + ' .postdetails,#post_' + postid + ' .postdetails .userinfo,#post_' + postid + ' .postdetails .userinfo_noavatar,#post_' + postid + ' .postbody').addClass(function(index, currentClass) {
            if (highestThreshold > 0) {
                searchString = new Array();
                if (highestObj['settings'] & 1) {
                    searchString.push('#post_' + postid + ' .posthead');
                if (highestObj['settings'] & 2) {
                    searchString.push('#post_' + postid + ' .postfoot .textcontrols');
                if (highestObj['settings'] & 4) {
                    searchString.push('#post_' + postid + ' .postdetails,#post_' + postid + ' .postdetails .userinfo,#post_' + postid + ' .postdetails .userinfo_noavatar');
                if (highestObj['settings'] & 8) {
                    searchString.push('#post_' + postid + ' .postbody');
                searchString = searchString.join(',');
                if (searchString == '') {
                    return '';
                $(searchString).addClass(function(index, currentClass) {
                        if (exploded[i].toString().match(/\btextcontrols/)) {
                            $('.postbitlegacy .postfoot .textcontrols span a').css('background-color', 'transparent');
                            $('.postbitlegacy .postfoot .textcontrols span.seperator').css('border-right', '1px #000000 solid');
                    return 'thanks_highlight_' + highestObj['color'];
            console.log('Colouring post ' + postid + ' with colour ' + highestObj['color']);
            return true;
    function _displayPost(postid) {
        if (thanksOptions.noRefresh) {
            return;
        var postCount = $('#postcount' + postid).attr('name');
        var extraParams = {
            'p': postid,
            'postcount': (typeof postCount != 'undefined' ? parseInt(postCount) : thanksOptions.postCount)
        var type = 'POST';
            type: type,
            url: 'showpost.php',
            var postbit = $('postbit', data).text();
                var postWrapper = $('#post' + postid);
            } else {
                var postWrapper = $('#post_' + postid);
            if (postbit) {
                var newpostbit = string_to_node(postbit);
                postWrapper.replaceWith(newpostbit);
                PostBit_Init(newpostbit, postid);
        return false;
    function timeStamp() {
        var d = new Date();
        return '[' + d.getHours() + ':' + d.getMinutes() + ':' + d.getSeconds() + '] ';
In Version 3.3.0 Code Is:
{var ftd=$(document),lastClick=0;thanksOptions.floodTime=parseInt(thanksOptions.floodTime);if(thanksOptions.vbversion>3)
{ftd.on('click','a[name=dbtech_thanks_downranked]',function(e)
{e.preventDefault();var postid=$(this).attr('data-postid');_displayPost(postid);});}
ftd.on('click','a[name=dbtech_thanks_button]',function()
{if(thanksOptions.floodTime>0)
{var d=new Date();var timenow=parseInt(d.getTime()/1000);if((timenow-lastClick)<thanksOptions.floodTime)
{alert(vbphrase['dbtech_thanks_must_wait_x_seconds'].replace('%time%',thanksOptions.floodTime).replace('%time2%',(timenow-lastClick)));return false;}
lastClick=timenow;}
var postid=$(this).attr('data-postid');if(typeof thanksOptions.thanksEntries[postid]=='undefined')
{thanksOptions.thanksEntries[postid]={};}
thanksOptions.thanksEntries[postid][$(this).attr('data-button')]=parseInt(thanksOptions.thanksEntries[postid][$(this).attr('data-button')])-1;_colourPost(postid);var extraParams={'securitytoken':SECURITYTOKEN,'do':'ajax','action':'entry','varname':$(this).attr('data-button'),'contenttype':thanksOptions.contenttype,'p':postid};var type='POST';var jqxhr=$.ajax({type:type,url:'thanks.php',data:(SESSIONURL?SESSIONURL+'&':'')+$.param(extraParams)}).done(function(data)
{var tagData=$(data),origData=data;data={thanksEntries:{},colorOptions:{}};var singleVals=['entries','actions','error'];if(tagData.find('colorOption').length)
{tagData.find('colorOption').each(function()
{var tagData2=$(this);if(typeof data.colorOptions[tagData2.attr('varname')]=='undefined')
{data.colorOptions[tagData2.attr('varname')]={};}
data.colorOptions[tagData2.attr('varname')][tagData2.attr('numclicks')]={color:tagData2.text(),settings:tagData2.attr('settings')};});}
if(tagData.find('thanksEntry').length)
{tagData.find('thanksEntry').each(function()
{data.thanksEntries[$(this).text()]=$(this).attr('numclicks');});}
for(var i in singleVals)
{data[singleVals[i]]='';if(tagData.find(singleVals[i]).length)
{data[singleVals[i]]=tagData.find(singleVals[i]).text();}
else if(singleVals[i]!='error')
{data['error']=origData;}}
if(data.error)
{alert(data.error);console.error(timeStamp()+"AJAX Error: %s",data.error);return true;}
$('#dbtech_thanks_entries_'+postid).html(data.entries);$('#dbtech_thanks_actions_'+postid).html(data.actions);if(typeof data.thanksEntries!='undefined')
{thanksOptions.thanksEntries[postid]=data.thanksEntries;switch(thanksOptions.contenttype)
{case'post':_colourPost(postid);_displayPost(postid);break;case'blog':break;}}
if(data.colorOptions)
{thanksOptions.colorOptions=data.colorOptions;}});});ftd.off('click','.dbtech-thanks-button-control').on('click','.dbtech-thanks-button-control',function(e)
{if($(e.target).closest('.dbtech-thanks-bubble-flyout').length==1)
{showWhoClicked.apply(e.target,[e]);}
else
return false;});if(thanksOptions.contenttype=='post')
{for(var postId in thanksOptions.thanksEntries)
{_colourPost(postId);}}
function showWhoClicked(e)
{var self=$(this);var buttonContainer=$(this).closest('.dbtech-thanks-button-control'),postid=buttonContainer.attr('data-postid'),button=buttonContainer.attr('data-button');var extraParams={'securitytoken':SECURITYTOKEN,'do':'ajax','action':'whoclicked','varname':button,'contenttype':thanksOptions.contenttype,'p':postid};var type='POST';self.qtip({content:{title:{text:vbphrase['dbtech_thanks_people_who_clicked'],button:true},text:vbphrase['dbtech_thanks_loading']+'...',ajax:{url:'thanks.php',type:type,data:(SESSIONURL?SESSIONURL+'&':'')+$.param(extraParams),once:false,success:function(data,status)
{if(data.errors)
{this.set('content.text',data.errors);}
else
{if(data.length<1)
{this.set('content.text',vbphrase['dbtech_thanks_noone_clicked']);}
else
{var html='<ul>';for(x in data)
{var profileurl=data[x].profileurl,avatarurl;if(!data[x].avatarurl)
{avatarurl='image.php?u='+data[x].userid+'&type=profile';}
else
{avatarurl=data[x].avatarurl;}
var img=$('<img>').attr('src',avatarurl).attr('alt',data[x].username),avatar=$('<a>').attr('href',profileurl).addClass('avatar'),username=$('<a>').attr('href',profileurl).addClass('username').html(data[x].musername),li=$('<li>'),usertitle=$('<div>').addClass('usertitle').html(data[x].usertitle);avatar.append(img);li.append(avatar);li.append(username);li.append(usertitle);html+=$('<div>').append(li).html();}
html+='</ul>';this.set('content.text',html);}}},error:function(jqXHR,textStatus,errorThrown)
{this.set('content.text',textStatus);}}},position:{my:'left top',at:'right top',viewport:$(window)},show:{event:'click'},hide:{event:'unfocus',fixed:true},style:{classes:'ui-tooltip-shadow ui-tooltip-light ui-tooltip-whovoted'}})
self.qtip('api').show();}
{if(typeof thanksOptions.thanksEntries[postid]=='undefined')
{return false;}
var highestThreshold=0,highestObj;for(var varName in thanksOptions.colorOptions)
{if(typeof thanksOptions.thanksEntries[postid][varName]=='undefined')
{continue;}
thanksOptions.thanksEntries[postid][varName]=parseInt(thanksOptions.thanksEntries[postid][varName]);for(var threshold in thanksOptions.colorOptions[varName])
{threshold=parseInt(threshold);if(thanksOptions.thanksEntries[postid][varName]>=threshold&&threshold>highestThreshold)
{highestThreshold=threshold;highestObj=thanksOptions.colorOptions[varName][threshold];}}}
if(thanksOptions.vbversion==3)
{$('#post'+postid+' tbody td').each(function(index,element)
{if($(this).is('.alt1, .alt2'))
{$(this).addClass(function(index,currentClass)
{var exploded=currentClass.split(' ');for(var i in exploded)
{if(exploded[i].toString().match(/\bthanks_highlight_/))
{$(this).removeClass(exploded[i]);}}
return(highestThreshold>0?'thanks_highlight_'+highestObj['color']:'');});}});}
else
{$('#post_'+postid+' .posthead,#post_'+postid+' .postfoot .textcontrols,#post_'+postid+' .postdetails,#post_'+postid+' .postdetails .userinfo,#post_'+postid+' .postdetails .userinfo_noavatar,#post_'+postid+' .postbody').addClass(function(index,currentClass)
{$(this).removeClass(exploded[i]);}}});if(highestThreshold>0)
{searchString=new Array();if(highestObj['settings']&1)
{searchString.push('#post_'+postid+' .posthead');}
if(highestObj['settings']&2)
{searchString.push('#post_'+postid+' .postfoot .textcontrols');}
if(highestObj['settings']&4)
{searchString.push('#post_'+postid+' .postdetails,#post_'+postid+' .postdetails .userinfo,#post_'+postid+' .postdetails .userinfo_noavatar');}
if(highestObj['settings']&8)
{searchString.push('#post_'+postid+' .postbody');}
searchString=searchString.join(',');if(searchString=='')
{return'';}
$(searchString).addClass(function(index,currentClass)
{if(exploded[i].toString().match(/\btextcontrols/))
{$('.postbitlegacy .postfoot .textcontrols span a').css('background-color','transparent');$('.postbitlegacy .postfoot .textcontrols span.seperator').css('border-right','1px #000000 solid');}}
return'thanks_highlight_'+highestObj['color'];});}}
{console.log('Colouring post '+postid+' with colour '+highestObj['color']);return true;}}
{if(parseInt(thanksOptions.noRefresh)==1)
{return;}
var postCount=$('#postcount'+postid).attr('name');var extraParams={'securitytoken':SECURITYTOKEN,'p':postid,'postcount':(typeof postCount!='undefined'?parseInt(postCount):thanksOptions.postCount)};var type='POST';var jqxhr=$.ajax({type:type,url:'showpost.php',data:(SESSIONURL?SESSIONURL+'&':'')+$.param(extraParams)}).done(function(data)
{var postbit=$('postbit',data).text();if(thanksOptions.vbversion==3)
{var postWrapper=$('#post'+postid);}
else
{var postWrapper=$('#post_'+postid);}
if(postbit)
{var newpostbit=string_to_node(postbit);postWrapper.replaceWith(newpostbit);PostBit_Init(newpostbit,postid);_colourPost(postid);}});return false;};function timeStamp()
{var d=new Date();return'['+d.getHours()+':'+d.getMinutes()+':'+d.getSeconds()+'] ';};});
Anyway how to find the Code? :
            type: type,
            url: 'thanks.php',
It's called "Minified JavaScript" and is a technique we employ when you download the product in order to compress the .js files so the performance of your site increases.
The code you're searching for can be found in the code you posted:
