Bug DragonByte SEO Installation Issue
Aashi
Hi , when i try to install XML file this error shows up ...
Database error in vBulletin 4.2.5:
Invalid SQL:
CREATE TABLE IF NOT EXISTS `dbtech_dbseo_urlhistory` (
`setting` VARCHAR(100) NOT NULL DEFAULT '',
`regexpformat` VARCHAR(100) NOT NULL DEFAULT '',
`rawformat` VARCHAR(100) NOT NULL DEFAULT '',
PRIMARY KEY (`setting`, `regexpformat`, `rawformat`)
) ENGINE=MyISAM;
MySQL Error : Specified key was too long; max key length is 1000 bytes
Error Number : 1071
Request Date : Saturday, November 10th 2018 @ 10:34:27 PM
Error Date : Saturday, November 10th 2018 @ 10:34:31 PM
Script : http://urdustorylove.com/admincp/plugin.php?do=productimport
Referrer : http://urdustorylove.com/admincp/plugin.php?do=productadd
IP Address : 185.244.215.241
Username : Ayesha
Classname : vB_Database_MySQLi
MySQL Version : 10.2.18-MariaDB-cll-lve
Server : 68.66.224.22
User Agent :
Please Help ... Thanks
You might be able to bypass this issue by manually running this query:
SQL:
PRIMARY KEY (`setting`(80), `regexpformat`(80), `rawformat`(80))
) ENGINE=MyISAM;
SQL:
) ENGINE=MyISAM;
Thank you very much Filip H. It solved the issue :)
Hello @Aashi,
