MistyMeanor
I just installed this and set up the points and such. It has a ton of duplicate categories in the drop down listings (example: threads, threads or referrals, referrals)
Also when setting up the point amounts there are TONS of duplicates on there as well. Points for Threads, Points for Threads or Points for Registration, Points for Registration.
The each one also has the point amount you can enter, if it's active or not, etc.
I tried to set all of the ones that duplicated to the same settings in order to maybe prevent problems just to try to work around these.
I just tried for example starting new threads and it's not showing ANY points given for starting them. Is this a bad install??
Can someone help me?
