Just tried a fresh install and get the following error, I have set all the requirements via the forms menu, settings, fields etc but upon making the post everything appears fine until I click submit and the following error appears, when I get back into the forum the actual thread has been submitted however none of the options which I created are showing on the post. I have checked all usergroup permissions etc and everything appears to be fine.
Database error in vBulletin 4.2.0:
Invalid SQL:
INSERT INTO vb_dbtech_dbforms_entry
(categoryid, statusid, questions, Club Experience, Playing Times, Gamertag, dateline, responses)
VALUES
(1, 1, 'a:3:{i:1;s:9:\"blah blah\";i:2;s:14:\"blah blah blah\";i:3;s:13:\"blah blah\";}', 'blah blah', 'blah blah blah', 'Unity Bluefin', 1364330939, 'a:2:{i:0;a:4:{s:6:\"userid\";i:1;s:6:\"postid\";i:261026;s:12:\"responsetype\";s:4:\"user\";s:8:\"dateline\";i:1364330939;}i:1;a:4:{s:6:\"userid\";i:1;s:6:\"postid\";i:261026;s:12:\"responsetype\";s:7:\"manager\";s:8:\"dateline\";i:1364330939;}}');
MySQL Error : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Experience, Playing Times, Gamertag, dateline, responses)
VALUES
(1, 1, 'a:3:' at line 2
Error Number : 1064
Request Date : Tuesday, March 26th 2013 @ 08:48:59 PM
Error Date : Tuesday, March 26th 2013 @ 08:49:00 PM
Script : http://www.*.com/forums/newthread.php?do=postthread&f=119
Referrer : http://www.*.com/forums/newthread.php?do=newthread&f=119
IP Address : *
Username : *
Classname : vB_Database
MySQL Version : 5.1.68-cll
