Bug Error when click on thread
bosss
I redownloaded and upload and install (overwrite) product file and now get this error wneh someone click on thread
PHP Warning: require(..../dbtech/usertag_pro/hooks/editor_construct.php): failed to open stream: No such file or directory in ..../vb/ckeditor.php(74) : eval()'d code on line 1
Fatal error: require(): Failed opening required '/home/mysite/public_html/forum/dbtech/usertag_pro/hooks/editor_construct.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/mysite/public_html/forum/vb/ckeditor.php(74) : eval()'d code on line 1
some help please?
regards
bosss
diabled product - because could not open any post or thread!
This can be resolved by uploading the contents of the upload folder to your /public_html/forum/ folder :)
Fillip H. i did it ...just for few minutes ago and when enabled product - gott same error -
please try yourself on my site - just click on some thread or post = blank page with error above!
please some help?
regards
bosss
now i checked and i have not this file - usertag_pro/hooks/editor_construct.php in my downloaded package!
Please Fillip H. some help or solutions?
now is product disabled and i can access my posts.
regards
bosss
Similar problem here, upgraded to the latest version and it kills the forum, just getting a white screen when a thread is clicked on
Same issue. Looks like a missing file or incomplete feature in the update. Can we have a fix please Fillip H.
Separately my update subscription expired yesterday but I presume I will get the patch which fixes the issue as your update broke the product.
Please some fix Fillip H. ...
3 users have same problem ... can you just answered what we must do?
regards
bosss
This has been resolved in a hotfix, if you download v3.2.2 and re-import the XML file this will now be resolved :)
If you have any further issues or questions, please feel free to start a new support thread. Thanks!
Legacy Advanced User Tagging
