adambloch
Hi there as some of the other people on this site have noted it took forever to install but got there in the end :)
I have tried to the setup the "manage buttons" and I get this message
Fatal error: Class 'THANKS' not found in /var/www/vhosts/audi-sport.net/httpdocs/vb/dbtech/thanks/actions/admin/button.php on line 34
Forum manager gives me this
Fatal error: Class 'THANKS' not found in /var/www/vhosts/audi-sport.net/httpdocs/vb/dbtech/thanks/actions/admin/forum.php on line 22
Search gives me this
Fatal error: Class 'THANKS' not found in /var/www/vhosts/audi-sport.net/httpdocs/vb/dbtech/thanks/actions/admin/search.php on line 35
Maintenance works fine
Repair Cache gives me
Fatal error: Class 'THANKS_CACHE' not found in /var/www/vhosts/audi-sport.net/httpdocs/vb/dbtech/thanks/actions/admin/repaircache.php on line 23
and settings works fine
Many thanks
Adam
Please ensure you have uploaded all files to their correct locations, and ensure that in your Plugin Manager, you have a "Global Initialisation - AdminCP" plugin set and enabled.
Ok strange I seem to have 2 of everything shall I uninstall or just delete one of each of them or is this normal?
(Pro) Postbit: Downrank Posts showthread_postbit_create [Edit] [Delete]
(Pro) UserCP Navigation - Cell Definition usercp_nav_start [Edit] [Delete]
(Pro) UserCP Navigation - Menu Hook usercp_nav_complete [Edit] [Delete]
Additional Datastore Fetching init_startup [Edit] [Delete]
Custom Admin Permissions - Check can_administer [Edit] [Delete]
Custom Admin Permissions - Field Set admindata_start [Edit] [Delete]
Custom Admin Permissions - Form admin_permissions_form [Edit] [Delete]
Custom Admin Permissions - Process admin_permissions_process [Edit] [Delete]
Delete Confirmation Override admin_delete_confirmation [Edit] [Delete]
Edit Post: Form Preparation editpost_edit_start [Edit] [Delete]
Edit Post: Update Values editpost_update_process [Edit] [Delete]
Editor Toolbar Hook editor_toolbar_end [Edit] [Delete]
Global Initialisation global_bootstrap_init_complete [Edit] [Delete]
Global Initialisation: AdminCP admin_global [Edit] [Delete]
Global Initialisation: ModCP mod_global [Edit] [Delete]
Member Info Profile Block member_build_blocks_start [Edit] [Delete]
ModCP - Navigation mod_index_navigation [Edit] [Delete]
Navbar Hook process_templates_complete [Edit] [Delete]
New Blog: Strip HIDE blog_post_newentry_start [Edit] [Delete]
New Reply: Form Preparation newreply_form_start [Edit] [Delete]
New Reply: Parse HIDE on Preview newpost_preview [Edit] [Delete]
New Reply: Parse HIDE on Thread Review newreply_form_reviewbit [Edit] [Delete]
New Reply: Strip HIDE From Multi-Quote newreply_post_quote [Edit] [Delete]
New Reply: Strip HIDE From Quote newreply_quote [Edit] [Delete]
New Reply: Update Values newpost_process [Edit] [Delete]
New Thread: Data Preparation threadfpdata_doset [Edit] [Delete]
New Thread: Form Preparation newthread_form_start [Edit] [Delete]
Notifications notifications_list [Edit] [Delete]
Post Data: Valid Fields postdata_start [Edit] [Delete]
Postbit Integration postbit_display_complete [Edit] [Delete]
Postbit: Factory postbit_factory [Edit] [Delete]
Process Page Text: Print Thread printthread_post [Edit] [Delete]
Show Post: Handle Attachment / Content Hiding showpost_post [Edit] [Delete]
Show Thread: Query showthread_query [Edit] [Delete]
Statistics Fetching: AJAX Quick Reply newreply_post_ajax [Edit] [Delete]
Statistics Fetching: Announcement announcement_query [Edit] [Delete]
Statistics Fetching: Private Message private_showpm_start [Edit] [Delete]
Template Caching cache_templates [Edit] [Delete]
Template Grouping template_groups [Edit] [Delete]
Thread Data: Valid Fields threadfpdata_start [Edit] [Delete]
User Data: Creation userdata_postsave [Edit] [Delete]
User Data: Deletion userdata_delete [Edit] [Delete]
Who's Online - Handle Activity online_location_unknown [Edit] [Delete]
Who's Online - Set Activity online_location_process [Edit] [Delete]
Edit each of them and check that their contents is identical. If they are, then yeah you should delete one of them. Press save after you edit the first one just in case vBulletin's product cache became corrupt.
