Question Fixing URL Format with DBSEO
JBlaze
Section Name: Elsword Online Discussion
Previous Section URL before removing vBSEO and the htaccess: www.gamekiller.net/elsword-online-discussion/
After installing DBSEO, current URL: GameKiller - Bringing The Pain To Each And Every Game
.htaccess I am using is the default one provided in the original installation files.
If possible I'd like to revert it back to the url format I had with vBSEO as I've been using that for years and thats what google indexed.
Really appreciate the help will definitely be upgrading to pro version if this works well.
As long as the config.xml file from vBSEO remains, you can still import. The product does not need to be installed.
If you have completely removed all references of vBSEO from your server, including the files, you will need to configure your URL formats to match your vBSEO format manually. This may also require the Pro version, to access the "Custom" format for each URL type.
I just purchased the premium version and and imported my vBSEO settings but URLS still aren't matching.
