GreyGhost
Hi, I did post this on vB org forums but realised be better to post it here...
I'm getting the following message when I try to change any vBSecurity settings in ACP.
"Forbidden
You don't have permission to access /admincp/vbsecurity.php on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request."
vB 4.2.2 - vBSecurity v1.1.3
Fresh vB install with a hand full of members and forums/post imported from phpbb3
Only other mod installed is DBTech Copyright Management v2.1.1
Have now disabled both in Manage Products but am still unable to change any settings.
UPDATE: Just installed vBShout and I'm getting the same Forbidden message when I try to change the settings.
"Forbidden
You don't have permission to access /admincp/vbshout.php on this server."
So I uninstalled vBSecurity and deleted all the files but this hasn't fixed it.
All other vB settings changes work fine, it's only DBTech mods that produce the error.
I've looked for any .htaccess and there's none and checked file permissions which all DBTech .php files are set to 0644 where all other vB .php files on the server are 0600. Tried changing them but it made no difference.
8-/
"Forbidden
"Forbidden
8-/
