Bug 'Forum display' page loads blank when addon is activated
fasterfind
VBSEO 3.5.2 and VB credits 2.0.0 don't seem to play well together.
Either plugin can function independently, but if both are active at the same time, 'forum view' pages will load no content. e.g. when the browser shows that is is done loading the page, you can select the 'view source' option and the result will be empty.
Testing
Tested on default skin.
Example URL
http://www.rpgreseller.com/introduce-yourself-20/
Curious, has anyone else reported incompatibility? Any known fixes or tweaks?
The problem first occurred on a prior version of vbulletin, vbcredits, and vbseo (I upgraded all three to current releases in hopes of seeing the problem resolve itself.)
Edit (forum)/includes/config.php and add this on its own line somewhere:
ini_set('display_errors', true);
then load the homepage again after turning on both addons. it should display an error that was originally hidden. paste it here, then remove the line and disable one of the addons again.
Legacy vBCredits II Deluxe
