ringnews24
Not sure if this has anything to do with DB SEO but here goes
I have 1000 + tags in Google webmaster with 301 error codes
Example of a link: http://www.ringnews24.com/boxingforum/tags/british boxing/index6.html?tag=british boxing&page=6
There was a problem with active content or redirects.
Google couldn't follow your URL because it redirected too many times.
The page isn't redirecting properly
Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
Cheers guys
I'm unable to assist with this issue due to a critical problem with your server configuration. For some reason I can't determine, it is impossible to correctly save the settings in the vBulletin Options.
I also can't find a way to override the php.ini file to turn "display_errors" on, which further hinders any debugging efforts.
I would recommend contacting your host and ask them to turn display_errors on, enable ini_set overrides and also set max_input_vars to 10000 or higher.
max_input_vars is still set to 1000. Please correct this as well as per my above post :)
Update: The issue has been taken care of on your site, but I would still recommend changing the above php.ini variable in order to avoid future problems :)
