Question How do I make my own addons for vBCredits (or vBShop)?
Jeremy
I've coded before, but never for a vBulletin mod or anything. Where would I start? Or is it not that simple?
It depends on what you mean by "coded" really, and what it is you're looking to do - are you looking to add mod compatability, add new features etc?
Your best bet would be to check out the coders forum on vb.org to pick up some stuff and take a simple mod from vb.org and try to make it do different things as you work out what everything is for =)
Cosmic
Legacy vBCredits II Deluxe
