lch8
I have installed dbseo on my test forum and forum urls appear to be redirecting correctly. I tested generating a sitemap, and urls in sitemap are in the correct format (i.e. Example Domain). However, when you hover over links in the forum, they appear in the standard vbulletin format (i.e. http://www.example.com/cars/showthread.php?t=12345). Can you please point me in the right direction or shed some insight as to where I should look to resolve this issue? I tried searching the forum here and made some adjustments, but I'm stuck without a solution. Thanks.
