Sorry, I'm a bit confused as to what you're asking - that's a SQL Query, you would run it either via the Execute SQL Queries page, or via phpMyAdmin.
There is no easy way to back up the settings at this time. You would need to modify your site's php.ini file then restart your web server in order to permanently apply the max_input_vars change.
