Alright,
I am looking forward to purchase this product since it cause effects in forum browsing and make it faster and smooth, so i downloaded the lite version and test by myself before purchase (thats what i did with the others products i bought already)
After the instalation of this product, i went to settings, turn it on the product and put yes to everything, then i tried to run test and it says:
vB Optimise is currently offline. Please enable and configure vB Optimise to run a system test.
Ok, i went again to its settings and try to see what is happening, then i found this option "vB Optimise: Opcache Operator", i choose each to make the test and this message is the following when i pick any of them:
vB Optimise: You have selected a cache method that vB Optimise has detected you cannot use, this may be because the extension required is either not installed or configured correctly on your server. Please contact your system administrator or hosting provider for more information.
So thats my obstacle, i don't have a clue what else to do at this point, i went to upload file then config.php and i saw something about xcache autenthification and also password there but i don't know what user and pw put there.
Please some assistance on this to try this product out
Regards
---------- Post added at 00:23 ---------- Previous post was at 00:02 ----------
Some updates:
I've set into the config the authentification admin and pw because i've set "yes" in the manage setting (last option)
I've click on filecache and apparently it worked out same as system test option, but i havent seen any positive impact in terms of speed browsing to my forums.
Regards
Some updates:
