I was thinking of purchasing vbOptimise, so I wanted to try the lite version first.
Installed it and could not find what cache dreamhost uses, so I was going to go down the list of the supported ones and run the test to see which worked. After selecting xcache, I can no longer make any changes to any setting in my admin panel because of the following error:
That line says:
So I guess it's not running on my VPS. My host disabled sudo access this past week, so it's not like I can even install anything anymore. I'll be moving to a new host soon, but I need this fixed first.
Problem is I should not be locked out of changing settings on my own forum, I can't even disable vbOptimise!!
How can I resolve this?
Warning: xcache_get(): XCache var cache was not initialized properly. Check php log for actual reason in ..../dbtech/vboptimise/includes/operators/xcache.php on line 23
That line says:
return xcache_get($this->id($id));
