Bug Missing USERGROUP settings
product installed successfully, when I went to configure usergroups there was no text identifying each particular setting - checkboxes are there though. I went ahead and turned all setting for Admin group and everything is working for now. presently waiting for correction to allow me to configure rest of my usergroups.
regards
UPDATE: I am purchased PRO version and evidently there a lots of settings that I do not have available to me.
I purchased Lifetime license for VBShout, price paid was $95 USD
I checked in the Clientarea and my vBShout package an option for me to update the license..
I purchased the PRO, correct???
apparently I do not have the PRO version.
Please advise.
Can you try going to the Language Manager and click [Rebuild All Languages]?
If that doesn't work, click Control Panel Home and make sure MySQL Packet Size is set to 128 MB or higher.
Please advise.
You do have the Pro version. The upgrade option is related to the fact that we have a vB5 licence that you can either replace your vB4 licence with, or buy a "Dual Licence" that gives you the Pro version of both the vB4 and vB5 versions for a discounted price.
If you do not wish to run a vB5 forum using the Pro version of this mod, feel free to ignore that upgrade option.
There is no way for me to setup individual usergroups because the text description for each setting is missing. Please advise.
The screen you are showing me is not from vBShout. vBShout only has 1 entry in vBulletin's "Usergroup Manager" screen.
I have edited my attachment... the second question mark brings up this admin help.
If you haven't done so already, please delete the following files from your /includes/xml/ folder:
* bitfield_vbshout.xml
* bitfield_vbshout_pro.xml
* cpnav_vbshout.xml
* cpnav_vbshout_pro.xml
* hooks_vbshout.xml
* hooks_vbshout_pro.xml
The new files are named:
* bitfield_dbtech_vbshout.xml
* bitfield_dbtech_vbshout_pro.xml
* cpnav_dbtech_vbshout.xml
* cpnav_dbtech_vbshout_pro.xml
* hooks_dbtech_vbshout.xml
* hooks_dbtech_vbshout_pro.xml
These instructions can also be found in the vBShout v5.4.0 Upgrade Notes, which is intended for forums upgrading from vBShout v5.3.x or lower.
anyway .. I am now trying to give unregistered user access to Shoutbox. please advise.
Instance Management -> Edit -> Usergroup Permissions.
As per the instructions, and my previous post, please make sure you delete the old files (if they exist) listed. Do not do anything with the new files listed.
