Bug Need Help!
predi
good! again for help. I just installed vbcredits activate receipt lite but this list of errors. I'm working on a version 4.2.2 Testing forum
Warning: Non-static method VBCREDITS::user() should not be called statically in ..../includes/functions.php(1851) : eval()'d code on line 1
Warning: Non-static method VBCREDITS::regular() should not be called statically in ..../global.php(37) : eval()'d code on line 1
Warning: Non-static method VBCREDITS::templates() should not be called statically, assuming $this from incompatible context in ..../includes/class_bootstrap.php(1419) : eval()'d code on line 2
Warning: Non-static method VBCREDITS::verify() should not be called statically, assuming $this from incompatible context in ..../includes/class_bootstrap.php(430) : eval()'d code on line 1
Warning: Non-static method VBCREDITS::process() should not be called statically, assuming $this from incompatible context in ..../dbtech/credits/credits_core.php on line 72
Warning: Non-static method VBCREDITS::init() should not be called statically, assuming $this from incompatible context in ..../dbtech/credits/credits_core.php on line 94
Warning: Non-static method VBCREDITS_VBULLETIN::navbartime() should not be called statically in ..../global.php(37) : eval()'d code on line 2
Warning: Non-static method VBCREDITS::display() should not be called statically in ..../dbtech/credits/credits_vbulletin.php on line 118
Warning: Non-static method VBCREDITS::init() should not be called statically in ..../dbtech/credits/credits_core.php on line 177
Warning: Non-static method VBCREDITS_VBULLETIN::navtabs() should not be called statically in ..../includes/functions_navigation.php(826) : eval()'d code on line 1
Warning: Non-static method VBCREDITS::shutdown() should not be called statically in ..../includes/functions.php(7920) : eval()'d code on line 1
Warning: Non-static method VBCREDITS::init() should not be called statically in ..../dbtech/credits/credits_core.php on line 341
Please edit your issue and enter your real forum URL in order for us to be able to provide you with the best possible support, thanks :)
is that not to damage my forum I'm doing on my pc. Since I'm making some changes and this may fail. But just in case I have also uploaded a test site foros.milhost.net/forum.php
Thank you :)
Please try upgrading to the latest version, which at the time of writing I believe is v2.1.1 Patch Level 1. These issues should be corrected in that version :)
Legacy vBCredits II Deluxe
