dopy
Basicly there's no scrollbar for mobile devices, and cause I have it set to oldest posts first mobile users can't scroll down to see the newest shouts, any way to solve this?
The issue is on first generation droids, but also on other mobile devices.
I am able to use 2 fingers to "pull" the scroll area that'd normally have a scroll bar.
Sadly this is something that cannot be fixed unless you set the height of the SB to accommodate the number of shouts you wish to display.
How would I do that? It's set to display 20 shouts but it's showing ALOT more than 20.
That's true but I don't wish to make my shoutbox any bigger and clog up the index page even more, I set it to only display 10 shouts on it, but it shows alot more, how would I fix that then?
Are you sure you set the max shouts to display in the right option? There are two, one for Detached and one for normal. Also ensure you are not viewing it in detached mode (it'll say &detach=1 in the URL) as that uses the "other number" :)
