computer22
another error (I am not a bughunter! I just find them on the go! ;) )
However, the problem is:
Whatever you set the category permissions to, vbulletin ALWAYS uses the permissions configured under "Manage Modules" - I've tested that with upload.
The problem is:
I a category where only the subcategorys should be used to keep it all well managed. But people can still upload the the category over the subcategory, even if the permission isnt set in the category permissions.
David got the admin login for the forums anyway, so he can test it.
Thanks again for reading that!
Other problems:
Even when changing the link in the admin configuration (download.php to dl.php) the link in the Transaction link is false. It's proabaly not using the variable.
Next thing: When deleting the old FILE (not the whole download, just one file) and uploading a new one, all screenshots and the icon is lost. Just the description stays.
Other problems:
Could you post separate bugs in their own thread. Will allow us to manage them better :)
I will investigate these issues.
I'm not quite sure I understand what you mean in your original post. Are you saying that permissions are not applying correctly in sub-categories?
Exactly. They don't apply correctly at all. It doesn't look for the setting in the Category Settings, it looks for the "Manage Modules" Settings.
I believe I have fixed this now. Could you upgrade your files from the customer area please :)
Legacy vBDownloads
