hmm, you shouldn't need one. I don't have one, I've never used Pinterest actually lol. I don't have a local image for it, the script pulls it down automatically and there is no login credentials specified. I thought it used a default but maybe they changed it.
Try opening the template
dbtech_gallery_view_image
Find
Pin It
Replace with
<img border="0" src="//assets.pinterest.com/images/PinExt.png" title="Pin It" />
Nothing yet.
I took a look with firefox and there is this code.
<Error><Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>5115331A07FA720D</RequestId>
<HostId>2fuAv8vn+7uWoE1tyEaOT5ovQ8NUOnfTHLt3zA1RyOoZ1EKyNdHIWfQMnrwrp+xJ</HostId>
</Error>
You doing this locally? I don't have the error but Fillip H. does, he said he's getting it because it's probably sending his localhost ip there and they don't allow that.
OKay, I may need a quick education on localhost.
Do you mean is case is the forum on my local computer (my home)
If so, no.
I have been doing a little research online and wondering if these are issues
DOCTYPE's
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
change to
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
Another item
the bookmarklet not catching the images etc in frames
I figured out the problem, it's on my end. I'm going to release a new version at the end of the weekend, I'll have the fix for it in there.
Patience Grasshopper. :p
I am sure he is going to get it out, he is also working on fixing other stuff and adding stuff to.
I was hoping you were wise enough to know the reference, as some younger people prob dont know about that show. ;)
It's 5:30am here, going to grab some shut eye then need to do some family stuff. If I do have it ready today, I doubt it will be before late night.
Sent from my T-Mobile G2 using Tapatalk 2
I finished it but ran into some problems installing on here and our 4.2 test site, looks like tomorrow before I'll have something
Legacy DragonByte Gallery
