jellybelly
Hi when i istalled the mod everyting was ok and i recalculated in the maitenance and now cannot select all using the inline mod
please can you help as i was assured that the inline mod would work before i purchased
thank you
I've been unable to confirm this issue on any test environment I have access to. Please try disabling all other modifications and see if the issue persists.
Are you viewing it in threaded or linear mode?
Linear mode is what's on this forum.
edit i am using
Enable Threaded / Hybrid Mode
Use this setting to enable or completely disable the Threaded and Hybrid thread display modes.
i tried using
Set this value to 'Yes' if you would like users (who have not explicitly set a preference) to view threads in the threaded display mode.
This setting will have no effect if 'Enable Threaded / Hybrid Mode' is set to 'No'.
still the same issue
it says in my usercp that we are using linnier oldest first
this was a know issue when i used post thanks 7.82 that is why i decided to use your modification
Are you sure the issue appears when you have APTL enabled, not when you have Post Thanks enabled?
There have been no other reports of this happening and I've been unable to replicate it myself - in fact, we use inline moderation on a daily basis here on DBTech :)
Hi thanks again for your reply it works ok when the the thanks mod is not enabled
would like me to give you admin permissions on my forum so you can see for me please
this problem was know withe abes mod
Hi was you able to acces my forum did you receive the passes
i have this morning disabled all my mods except for profile hover and vbshout i have only left your three mods enabled and it is still doing the same i cannot select all using inline mod
this was a problerm withe abes mod that is why i unistalled and purchased your version
http://www.vbulletin.org/forum/showthread.php?t=231666&page=112
Originally Posted by steve1966 View Post
does anyone have a problem with the inlinemod not working correctly when this mod is enabled?
thanks
Yes you cannot use "select all", it's a known issue. I guess the Javascript must clash in some way. I gave up and took the "select all" option out instead.
as i have disabled my other mods do you think you will be able to fix this issue? because i need the inline mod working on my forum?
thank you
I see the issue, I'll fix it in the next bugfix release :)
In the meantime, you can use the checkboxes on the posts themselves :)
