Bug Problem with (Pro) Forum Display Query Enhancement
neogeox
I have a conflict with a code and a cache feature of vBOptimise 2.7.1
I've noticed that If I deactivate the feature (Pro) Forum Display Query Enhancement on your addon everything works well, but if this feature is active then I get a Mysql error.
I think is related with your "hack" for forumdisplay.php so I would like to ask you if you knows what could be the solution to solve this problem because I really need this working. Thank you for your support.
MYSQL ERROR
SQL:
Database error:
Invalid SQL:
    SELECT COUNT(*) AS threads,
        SELECT COUNT(*) AS newthread
        FROM thread AS thread
        WHERE forumid = 2
        AND lastpost > 1613348783
        AND open <> 10
        AND sticky = 0
         AND visible IN (0,1,2)
        */ WHERE forumid > 0 AND  sticky = 0    AND visible IN (0,1,2)
    ) AS newthread
    WHERE forumid = 2
    AND sticky = 0
    */ WHERE forumid > 0 AND  sticky = 0    AND visible IN (0,1,2);
MySQL Error   : You have an error in your SQL syntax; check the manual that corresponds to your MariaDB server version for the right syntax to use near '*/ WHERE forumid > 0 AND  sticky = 0    AND visible IN (0,1,2)
    ) AS newthre' at line 14
Error Number  : 1064
Classname     : vB_Database_MySQLi
MySQL Version : MariaDB
What version of MySQL are you running?
MySQL Version : 10.1.48-MariaDB
Note: vBoptimise works correctly with (Pro) Forum Display Query Enhancement activated, but crash when active the other addon (requiring forumdisplay) that I really need working.
You may be able to play around with the execution order of the plugins, but addon compatibility can't be guaranteed, so you may need to turn this feature off in vB Optimise instead.
Changing the execution order worked, no errors are displayed, but now the paginations has disappeared :/ I hate vB!
By the way, Is there much difference in terms of speed/load between having (Pro) Forum Display Query Enhancement enabled or disabled?
Hello @neogeox,
We hope your ticket regarding vB Optimise has been addressed to your satisfaction. This ticket has now been scheduled to be closed.
Hello @neogeox,
As we have not heard back from you, your ticket regarding vB Optimise has now been closed.
