Bug problems with Pro version
-Statistics and Log just give "File not found".
-auto pm displays "this is not available for your usergroup" no matter what settings are set.
-This message display s" Attention xxx, the staff at xxx, would like to let you know you have, 19 new private message(s). You can view them Here."
Displays at the top of the messages but clicking "Here" does nothing.
This has been resolved on your site. You need to rename the admincp directory inside the upload folder when you have renamed the vB ACP and you are installing modifications, before uploading :)
Can you please provide step-by-step instructions for how to replicate this issue? As in, what page do I go to, what do I click on, etc. This will help me help you faster :)
The user account you have provided me with does not have any PMs. Can you please send a PM to this user?
I have that same issue. If I goto the DragonByte Tech: vBSuper PM's Auto Reply Settings and have Founder checked then I get the not available notice. If I uncheck it then I get the settings page but then the link in the My Setting is gone? I think they are backwards..
I've made multiple changes to v1.2.0 that should resolve this. If you re-download v1.2.0 and re-upload all the files (re-importing the XML isn't needed) then this should be resolved :)
Legacy vBSuper PM's
