jl255
Was told that a new release of vbcredits is coming within a few days to correct the recalculation function of users. When will this be released? Need it urgently in order for me to officially relaunch vbcredits on my site. Tks.
If you download the pro files right now, the patch for that should be in place and you may proceed with the recalculation.
It's most likely what we refer to as a Hotfix, i.e. you simply download the files and re-upload them to your server :)
Recalculate doesn't do anything!
I simply want to divide all members' credits by 3. I put in the formulate [credits]/3 and run. It says XXX members updated and i see their updated credits in the lines below in the admincp.
However, when i pull out their records again, their credits are all BACK TO THE PREVIOUS credit values. Even at the front-end, its the same, their credits remain unchanged!!
What's going on???
Are you sure it doesnt update everyone, or just you? I tried it locally, and it did update everyone, except me (which is a bug, but less so :p)
I am having this same issue. I cannot adjust the credits of the logged in admin negatively. This is the case whether I use recalculate to 0 or whether I enter 0 specifically, it will not subtract credits from the admin.
I just downloaded the files yesterday so I should have the most recent version.
If it helps, I did not have this issue with the free version.
It wasn't something that got messed up in the upgrade process either, as I did a full wipe of the board before installing the pro version.
the download has been hotfixed for this. just the core and admin files need to be uploaded (no need to import xml)
Legacy vBCredits II Deluxe
