Question Rotating Banner Location --> Footer
GoodApples
Can I see a screen shot for the Footer Location?
I would like to see what it's suppose to look like as I do not see anything.
DragonByte Tech: vBDonate - Rotating Banner Settings --> Rotating Banner Location --> Footer
Also when it's in the Testing option. How does that work? <-- again I do not see anything.
It's most likely something on my end which I am looking into it. :)
Actually ignore the Testing setting and the Footer setting. The testing one I was trying a different location, as for the footer setting, for some odd reason it will not work there, but I will continue to find out why.
I simply forgot to remove those two defunct settings when I packaged it up. ;)
I removed those options now, so if you download the product and re import the new xml you will not see them.
Legacy vBDonate
