Question Separating Blog Entries from template_hook.postbit_userinfo_right_after_posts
Madhatterr
Hello, I can't figure out how to separate the blog entries from the template_hook.postbit_userinfo_right_after_posts. The hook seems to be the necessary code in the postbit_legacy template that allows the tabs to show, as they were gone when I deleted it in attempting to remove the duplicate blog entries from showing.
I'd like to be able to fix it so that the blog entries shows inside the tabs and not above them.
If you delete the contents of the blog_postbit or whatever the default vB blog postbit template is, that should work :)
That did it, thank you!
---------- Post added 26th March 2012 at 14:06 ---------- Previous post was 23rd March 2012 at 11:18 ----------
Is there a conditional I can wrap the code in that will show it only if the member has posted a blog and therefore has entries to count? The formatting is off if they don't have a blog. I know that's not really your guys' area or anything, I've just ran out of places to look for an answer :)
That's not possible when using the PBTabs display, it shows 0 when there's no entries :)
Legacy Postbit Tabs
