BrianC
Hey the shoutbox is great! How do I put it on the content.php page. If you can give good detail I will appreciate it. Thanks!:confused:
In your Instance Management -> Edit -> under Shoutbox Deployment, change to "index,vbcms"
You'll then need to use manual placement, just follow the instructions in the text in those options you just accessed.
@The blog entry: Just move the variable you manually added to the CMS template further down the page.
