Hi after i disable Shoutbox position because i need the test only the detach mode, now dont show the option so i can choose the position "disable, above, Header or navbar etc..." i dont remember the options?
Can someone tell-me the correct place where i can see this option or this is a Bug?
Best Regards
Best Regards
