CharlieDelta
I received a message from one of my users stating he could not see any shouts in the shout box. I checked it and everything was fine for me. I message him back stating it was fine. I then go back to check again and I am now having the same problem.
The archive is loading fine and showing any newly typed messages.
This is happening on both of my sites. Very strange.
Yeah that's what I just discovered there too - it was a .js file change that also required a product XML re-import.
Hi Fillip H.,
I have had to re-install the xml again on both sites as the shouts were not appearing again. Will this keep happening?
Also, I have this blank menu in my admincp. admincp.webp I am assuming it is from the Pro mix up.
How do I get rid of that?
Thanks
Try renaming every file that starts with cpnav_ to -cpnav_ (add the - in front) except for cpnav_vbulletin.xml
Then rename them back one-by-one until you find the culprit.
Could be a cache somewhere.
Check the template dbtech_vbshout_shoutbox, if the following line is there:
<script type="text/x-jquery-tmpl" name="dbtech_vbshout_shouttype_me" data-instanceid="{vb:var instance.instanceid}">
and NOT
<script type="text/x-jquery-tmpl" id="dbtech_vbshout_shouttype_me">
Then re-importing the XML will do nothing to change the output, and the issue is not in vBShout.
Have you recently enabled the Page Speed Optimization option given by your hosts.
In my case it was Dreamhost. I once had this problem. Shouts would not load but the Shoutbox would be there. This was happening whenever I enabled Page Speed Opt option. Did not know why this happened as it messed up the Forum Side blocks too along with the shoutbox. I just disabled the PSO option and went in for VbOptimise. Everything works fine now.
Seems to be working fine now. Flushed the cache and made each member who was having problems do the same on their browser and now all is good.
Thanks for the tip riskreward.
Thanks for the help Fillip H..
