Bug Sitemap problems - script execution timeout
janslu
I've been trying to check why I don't have the sitemap files renewed (after the original ones created by version 1.0.2 I think). There's a script execution timeout in php error log:
PHP Fatal error: Maximum execution time of 90 seconds exceeded in [...]/dbtech/dbseo/includes/library/attachment.php on line 189
As a side note - when I ran the sitemap manually, even if the process ended with an error - cronjob doesn't start with the following error:
"The sitemap is currently being generated in the admin control panel. The scheduled task will not run while the sitemap is being built in the control panel." What can I do to reset the process later?
You need to reduce the number of items executed per page. If your server can't handle 30k items per page, reduce that number to something like 10k.
Then, kill the sitemap session by clicking Build Sitemap and following the on-screen instructions.
Once this is done, attempt to build the sitemap again via the AdminCP. If this completes successfully, wait for the cron job to run.
