Em Kay
While the feedback appears to be calculating correctly, the neg feedback is not showing in the number counts..
NM the arrows under the months thingy :P
PS Thank you so much for the quick work on the updates for the bugs. Ill have my people run through this update and give it a good hammering to see if its now workable to go live in the next week or so :) as usual :P I'll harass you on here :D
You're awesome Mokonzi!
I'll check out why the count isn't working. :)
Thanks for the commendation. I'm working as quickly as I can in the limited time I have at the moment. It's good that the feedback is coming back on issues as it helps smooth out the mod quicker for everybody. :)
"stock" affecting feedback
I think I found a connection between stock on listings and the possible feeback issue. It seems to only cause a hang up and not registering feedback when a stock amount is input.
I think the two issues were different after all... :D
I've fixed the feedback count not working correctly now. :)
You don't happen to have the MySQL error that occurred for the feedback error? I've not been able to recreate it with the stock issue, but a fix I've introduced elsewhere might be why. :)
Just the one that I posted about the recent searches...
Legacy DragonByte Classifieds
