Em Kay
When adding a specification, after selecting Always in "manage forms" in the ACP, going to add a listing, shows more than one "Specification" box. It seems after clearing the cache and rebuilding, if there were previous specification removed, they're not completely removed from the front end of the listing form.
The two blank spots...are left overs of the two specs I deleted while the Clone or Original is the one thats active.
One disappeared but in the next listing both blanks were back :P I think we have code gremlins hiding in our server :P
I'll sign up to your forum, and if you are able to give me access to the ACP I can take a closer look at the problem. :)
You'll have to message OccultScientist or Junglist for access to the ACP. But I found your account and changed your user group so you can access our testing group.
It might be that you will have to tell me where to look and I can report back to you :P
Can you run the Rebuild Cache on the Classifieds in the ACP? Might be worth trying that if you can. I think is the first time I'm aware of a site using Classifieds with a multi server setup. :)
Just to let you know I fixed this issue by deleting the category it was showing up in and recreating it. The specs now display as should :)
Legacy DragonByte Classifieds
