Hi!
Today i want to install the DBT-A&A AddOn in my working-Forum. Like i was ever doing, i test this BEFORE in XAMPP-Test ground with an actual backup of my SQL-DB.
When i was purchasing the mod, all was working fine in XAMPP (was a clean install from vBulletin), but now the Add-on importer stops at:
And brings me an SQL-Error:
Datenbankfehler in vBulletin 4.2.0:
Invalid SQL:
UPDATE vbs_user
SET dbtech_vbactivity_pointscache = 44662.7,
WHERE userid = 2;
MySQL-Fehler : You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'WHERE userid = 2' at line 3
Fehler-Nr. : 1064
Fehler-Zeit : Friday, 19.10.2012 @ 23:01:28
Datum : Friday, 19.10.2012 @ 23:01:45
Skript : http://localhost/fftest/admincp/plugin.php?do=productimport
Referrer : http://localhost/fftest/admincp/plugin.php?do=productadd
IP-Adresse : ::1
Benutzername : #CHANGED_FROM_ME #
Klassenname : vB_Database
MySQL-Version : 5.1.37
Stack Trace:
#0 vB_Database->halt() called in [path]\includes\class_core.php on line 426
#1 vB_Database->execute_query() called in [path]\includes\class_core.php on line 444
#2 vB_Database->query_write() called in [path]\dbtech\vbactivity\install\110.php on line 77
#3 require_once([path]\dbtech\vbactivity\install\110.php) called in [path]\dbtech\vbactivity\includes\class_install.php on line 130
#4 DBTech_Install::install() called in [path]\includes\adminfunctions_plugin.php(1174) : eval()'d code on line 2
#5 eval() called in [path]\includes\adminfunctions_plugin.php on line 1174
#6 install_product() called in [path]\admincp\plugin.php on line 1751
Do you have an idea?
Thank you in advance
D.
Updating Version Number To: 1.1.0
Altered Table: vbs_dbtech_vbactivity_pointslog
Altered Table: vbs_user
Invalid SQL:
UPDATE vbs_user
WHERE userid = 2;
Fehler-Nr. : 1064
IP-Adresse : ::1
Stack Trace:
D.
