Bug "Thanks" clicks not working after vB Upgrade (3.8.11) and PHP upgrade (to 7.1)
janklerks
Upgraded PHP to 5.6 on the forums, and the forum software to vB 3.8.11 (beta). I also went ahead and upgraded the "Thanks" addon to 3.6.3. The upgrade itself crashed due to a modification of the dbtech_thanks_entrycache table (which is about 11GB on our forum), but after manually modifying the column, the update completed.
Somehow, somewhere, however click on the "like" button (we have a single button to "like" a post) now produces no actual "like". Also the "likes" under a user's name disappear when it is clicked (the button briefly disappears and reappears too)
BEFORE CLICKING:
AFTER CLICKING:
(red circle is where it should say "X liked this post"
I receive no PHP errors or warnings when the button is clicked, either. (Unless warnings are disabled in the addon, I haven't dug into the code too much).
The same thing happens in all locations on the forum where the thanks addon is enabled (visitor messages, social groups, etc)
Thanks in advance for any help you can provide.
Have you checked your PHP error log? Have you tried using the Compact style to see if that works for you?
Sorry, should have been more clear.
I receive no errors or warnings in the php error log when the button is clicked.
The same thing happens with "compact" style.
Update: The integration through Tapatalk does work. I was able to successfully "like" a post using it.
I wonder if this is some javascript issue with vB 3.8.11...
Can you please double-check you've not customised any APTL templates and if you have, can you please revert them?
The mod has been tested on 3.8.11 so that shouldn't be an issue :)
We found the issue. or, at least a work-around.
From one of our moderators:
Tiago Costa said:
I've found the problem. There is a missing tag "data-contenttype" in the <a> tag of the like button. An example of the tag of the post I'm quoting:
<a href="javascript://" name="dbtech_thanks_button" data-postid="139346714" data-button="likes"><img src="dbtech/thanks/images/likes.png" alt="Likes" title="Likes" border="0"></a>
The "data-" attributes are:
  • data-postid
  • data-button
So if I use Chrome Developer Tools or Firebug and edit this tag to have one more attribute:
<a href="javascript://" name="dbtech_thanks_button" data-postid="139346714" data-button="likes" [B]data-contenttype="post"[/B]><img src="dbtech/thanks/images/likes.png" alt="Likes" title="Likes" border="0"></a>
I edited the dbtech_thanks_postbit_entries_actionbit to this:
<span class="dbtech-thanks-button-control"<if condition="!$show['_cannotseeclicks']"> data-contenttype="$contenttype" data-button="$button[varname]" data-postid="$post[postid]"</if>>
	<a href="javascript://"<if condition="$button['canclick']"> name="dbtech_thanks_button" data-postid="{$post[postid]}" data-button="{$button[varname]}" data-contenttype="$contenttype"<else /> style="cursor:default;"</if>><img src="$button[buttonimage]" alt="{$button[title]}" title="{$button[title]}" border="0" /><if condition="!$vboptions['dbtech_thanks_notext']"> {$phrase}</if></a>
	<if condition="$vboptions['dbtech_thanks_cloud_displaystyle'] == 2">
		<span class="dbtech-thanks-bubble-flyout">
			<!--<i></i>
			<u></u>-->
			<span class="dbtech-thanks-bubble-content clickcount"<if condition="!$show['_cannotseeclicks']"> data-button="$button[varname]" data-postid="$post[postid]"</if>>$button[clickcount]</span>
		</span>
	</if>
</span>
I've hotfixed v3.6.3 with the code in question, if you re-import the XML file and then revert that template it should work :)
Thanks.
TBH I wasn't really looking forward to trying to explain how our code edited and pushed out to all 12 servers, since we don't use FTP :)
Hello janklerks,
