Bug Thanks counter with wrong number
mwyrsch
Hi there
I do have some posts where the counter shows the wrong number:
I checked the database (thanks table) and there is always the correct number for such a post but it displays the wrong one against the user.
Did I make something wrong or how can this happen?
Regards,
Marco
Go to DBTech - Post Thanks -> Maintenance -> Rebuild Statistics, then Rebuild Button Click Cache - this should clean up any such issues :)
Are you sure you ran all the maintenance actions described, especially the Button Entry Cache ones? This is not an issue myself nor anyone else have been able to replicate.
Yes I did: Rebuild Statistics and then Rebuild Button Click Cache and then also in the Menu "Repair Cache". Ok if I'm the only one who has this problem, I have to accept this.
