Not sure where to start,
It seems like every time I enable dbseo from cp my site crashes, pages cant be found- pretty much just falls apart
Most recently I have disabled all of my plugins
uninstalled and reinstalled DBseo
Edited and reedited .htaccess file
So here is what I have currently
DBSEO plugin disabled in plugins and turned off /dbseocp/
Admincp--> options-->Site Name / URL / Contact Details -->
URL of your forum. = https://domain.com
URL of your home page. = https://www.domain.com
This is my current working .htaccess File
RewriteEngine on
# RewriteBase /forum/
# Options -MultiViews
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.*$ - [NC,L]
# Forum
RewriteRule ^threads/.* showthread.php [QSA]
RewriteRule ^forums/.* forumdisplay.php [QSA]
RewriteRule ^members/.* member.php [QSA]
RewriteRule ^blogs/.* blog.php [QSA]
RewriteRule ^entries/.* entry.php [QSA]
# MVC
RewriteRule ^(?.*?)(?:/|$))(.*|$)$ $1.php?r=$2 [QSA]
# Check MVC result
RewriteRule ^(.*)$ - [NC,L]
RewriteRule ^(.*)$ - [R=404,L]
I have tried adding the below code to above and separately I have added the below to the .htaccess I had from VBseo
RewriteEngine On
RewriteCond %{REQUEST_URI} !(admincp/|dbseocp/|modcp/|cron|mobiquo|forumrunner|api\.php)
RewriteCond %{REQUEST_FILENAME} !/(admincp|dbseocp|modcp|clientscript|cpstyles|images)/
Friendly URLs are set to standard
gave up on global https://
seems like there no real good way run mixed content on vb without the browser blocking or throwing warnings for user embedded content.
I guess ill try the configurations again tomorrow w/o https
Tired and should give up but i'm stubborn
First attempt
resulted in 404
Not Found
The requested URL /announcements/30860-sfp-site-upgrade-need-your-help-post247164.html was not found on this server.
Apache/2.2.22 (Ubuntu) Server at domain Port 80
my traffic is dropping quickly in the past week since upgrading and trying to swap out vbseo for dbseo
please help me
RewriteEngine on
# Forum
# MVC
# Check MVC result
RewriteEngine On
First attempt
resulted in 404
Not Found
please help me
