pityocamptes
Need help getting it back up. Not sire if it was the htaccess changes or the friendly url changes to standard and this for the htaccess:
RewriteEngine On
#Options -MultiViews
RewriteCond %{REQUEST_URI} !(admincp/|dbseocp/|modcp/|cron|mobiquo|forumrunner|api\.php)
RewriteCond %{REQUEST_FILENAME} !/(admincp|dbseocp|modcp|clientscript|cpstyles|image s)/
vs this that I originally had
Options -MultiViews
RewriteCond %{REQUEST_FILENAME} -f [OR]
RewriteCond %{REQUEST_FILENAME} -l [OR]
RewriteCond %{REQUEST_FILENAME} -d
RewriteRule ^.*$ - [NC,L]
# Forum
RewriteRule ^threads/.* showthread.php [QSA]
RewriteRule ^forums/.* forumdisplay.php [QSA]
RewriteRule ^members/.* member.php [QSA]
RewriteRule ^blogs/.* blog.php [QSA]
RewriteRule ^entries/.* entry.php [QSA]
# MVC
RewriteRule ^(?
.*?)(?:/|$))(.*|$)$ $1.php?r=$2 [QSA]
# Check MVC result
RewriteRule ^(.*)$ - [NC,L]
RewriteRule ^(.*)$ - [R=404,L]
# FeedBurner
RewriteCond %{HTTP_USER_AGENT} !FeedBurner [NC]
Also, nothing has been written to my store_sitemap folder I created. Also, do I need to go into google and submit my sitemap link in my analytics page? Thanks.
Also,when I click on the generate manual sitemap I get an error that file does not exist!!!! I installed everything 100% correctly!!!!!!!
Not Found
The requested URL /dbseocp/dbseo.php was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request
RewriteEngine On
Options -MultiViews
# Forum
# MVC
RewriteRule ^(?
# Check MVC result
# FeedBurner
Not Found
