ifitsmedia
Trying to set up this plugin on a fresh vBulletin installation that I am using as a test forum. The forum is brand new, it has no other plugins installed, no mods, and is using the default theme.
When I try to add an Achievement, I'm told I need to add Criteria. I try to add Criteria but the dropdown select for "Field" is empty (there's nothing to select) and when I try to add a Criteria I get this error:
"A required field called typeid is missing or has an invalid value."
When I visit "Points Settings" there is nothing there except a "Save" button and "Reset" button.
Screenshots:
Am I missing something or is this normal? Is there a guide for setting this plugin up? The documentation doesn't really explain what to do initially.
Thanks.
Screenshots:
Thanks.
