Question VBAvatars body shapes
You can add different Avatar Styles and design your own images following the same pattern as the current ones :)
Many thanks for prompt response.
Can you please put me in the right direction on how to create/add/modify a fat body?
You'll need a photoediting or drawing software to be able to create your own, there are a few free templates you could use by google searching it but i personally wouldn't recomend making different types of body as some clothes will not fit on them or look odd if you go too extreme.
if you decide to make your own be sure to upload them to your /parts/ folder located in dbtech/avatars/images/ this folder is where you upload all of your avatar parts and where you can find all of the default DBtech images.
Legacy vBAvatars
