When vbShout is activated, it works fine, but it causes my advertiser's footer text links to NOT appear. No actual error breaking the site. The advertiser's text links just don't appear at all.
In my footer template I have:
This hook basically is a php include that pulls a file
Then the content of that ad_network.php file:
The text file that it's referring to is just full of standard html of text links. No php in there or sql calls or anything.
Any ideas? Anything I can provide you to make this more obvious. Once I get this sorted out and I figure out how to get your shoutbox in my header, I'm going Pro if that's any incentive to help me
<div class="gensmall" align="center">{vb:raw ad_network}</div>
ob_start();
$ad_network_output = require_once('--MyServerPath--public_html/ads/ad_network.php');
ob_end_clean();
if($ad_network)
$templater = vB_Template::preRegister('footer', array('ad_network' => $ad_network, 'ad_network_output' => $ad_network_output));
<?php
// Last update: July 10, 2006 3:10 pm (PST)
// $LastChangedRevision: 656 $
$ad_file = '--MyServerPath--/public_html/ads/ad_network_ads.txt';
$ad_separator = ' | ';
$ad_target = '0_blank';
$ad_class = '';
$ad_options = 0;
if (false && function_exists('date_default_timezone_set')) {
if((strlen(ini_get("date.timezone")) < 1) && (strlen(getenv("TZ")) < 1 )) {
date_default_timezone_set("America/New_York");
if (!function_exists('file_get_contents_an')) {
function file_get_contents_an($url) {
$string = "";
if (substr ($url, 0, 7) == 'http://') {
$url = parse_url ($url);
$handle = @fsockopen ($url['host'], 80, $errno, $errstr, 5);
if ($handle!==false) {
fwrite ($handle, "GET $url[path]?$url[query] HTTP/1.0\r\nHost: $url[host]\r\nConnection: Close\r\n\r\n");
$enableStreamTimeOut = stream_set_timeout($handle, 5);
while (!feof($handle)) {
$string .= @fread($handle, 40960);
$string = explode ("\n", $string);
$string = array_pop ($string);
if(true == $enableStreamTimeOut) {
$info = stream_get_meta_data($handle);
if($info['timed_out']) {
echo "Connection timed out";
} else {
echo "unable to set timeout";
fclose($handle);
} else {
//TODO: Hide during normal operation as server may become unavailable from time to time
echo "Unable to connect to ad server<br />\n";
echo "$errstr ($errno)<br />\n";
} else {
$string = file_get_contents($url);
return $string;
if (!function_exists('make_seed')) {
function make_seed() {
list($usec, $sec) = explode(' ', microtime());
return (float) $sec + ((float) $usec * 100000);
mt_srand (make_seed());
//PHP 4.2.x Compatibility function
if (!function_exists('file_get_contents')) {
function file_get_contents($filename, $incpath = false, $resource_context = null)
if (false === $fh = fopen($filename, 'rb', $incpath)) {
trigger_error('file_get_contents() failed to open stream: No such file or directory', E_USER_WARNING);
return false;
clearstatcache();
if ($fsize = @filesize($filename)) {
$data = fread($fh, $fsize);
} else {
$data = '';
while (!feof($fh)) {
$data .= fread($fh, 8192);
fclose($fh);
return $data;
//if (!isset($_SERVER)) $_SERVER = $HTTP_SERVER_VARS;
if (!isset($_SERVER) && isset($HTTP_SERVER_VARS)) {
$_SERVER = &$HTTP_SERVER_VARS;
for ($i = 0; $i <= 11; $i++) {
$path = substr ('../../../../../../../../../../', 0, $i * 3);
if (file_exists ($path . $ad_file)) {
$ad_file = $path . $ad_file;
break;
$server_remote_addr = isset($_SERVER['REMOTE_ADDR']) ? $_SERVER['REMOTE_ADDR'] : "";
if(strlen(trim($server_remote_addr)) <= 0) {
$ad_network = '$_SERVER[\'REMOTE_ADDR\']: ' . $server_remote_addr . 'is unavailable.';
} else if(false == file_exists($ad_file)) {
$ad_network = 'Unable to locate the file:' . $ad_file;
} else if(false == is_writable($ad_file)) {
$ad_network = 'Unable to write to the file: ' . $ad_file;
} else {
$ad_network = array();
$ads = file_get_contents_an ($ad_file);
$ads = explode ('<ad_break>', $ads);
$ads_temp = explode ('|', $ads[0]);
$NUM_ADS = count($ads);
$MAX_ADS = $ads_temp[4];
$LAST_UPDATE = $ads_temp[0];
$MIN_UPDATE = $ads_temp[6];
$MAX_UPDATE = $ads_temp[5];
$CUR_TIME = time();
#4/24/2007 8:12:52 AM|216.9.35.51|us82jsdd|1000|1800|5|1|MSIE-Firefox-Safari-Netscape-Opera
#1177716953|36|216.9.35.51|us82jsdd|1000|1800|5|1|MSIE-Firefox-Safari-Netscape-Opera
#echo $NUM_ADS . ' | ' . $MAX_ADS .' | '.$LAST_UPDATE.' | '.$MAX_UPDATE.' | '.$CUR_TIME;
$would_block = false;
$file = fopen($ad_file, 'r+');
if (flock ($file, LOCK_EX|LOCK_NB, $would_block) && !$would_block) {
#IF ((NUM_AADS < MAX_ADS+1) AND ((TIMESTAMP+MINIMUM_UPDATE) < CurrentTime)) ||
if ((count ($ads) < $ads_temp[4] + 1 && $ads_temp[0] + $ads_temp[6] < time()) || $ads_temp[0] + $ads_temp[5] < time()) {
$new_ad = file_get_contents_an ('http://ads.digitalpoint.com/network.php?c=' . $_SERVER['SERVER_NAME'] . '&type=link');
if ($new_ad) {
$ads_param = explode ('<ad_param>' , $new_ad);
$new_ad = $ads_param[1];
unset ($ads_param[1]);
$ads_temp = explode ('|', $ads_temp[0] . '|' . $ads_temp[1] . '|' . $ads_temp[2] . '|' . $ads_param[0]);
} else {
$ads_param = array_slice ($ads_temp, 3, 6);
$ads_temp[1] = (integer)$ads_temp[1] + 1;
if ($ads_temp[1] > $ads_temp[4]) $ads_temp[1] = 1;
$ads[0] = time() . '|' . $ads_temp[1] . '|' . gethostbyname('validate.digitalpoint.com') . '|' . implode ('|', $ads_param);
if ($new_ad) {
$ads[$ads_temp[1]] = $new_ad;
if (count ($ads) > $ads_temp[4] + 1) $ads = array_merge ((array)$ads[0], (array)array_slice ($ads, -$ads_temp[4]));
fwrite ($file, implode ('<ad_break>', $ads));
ftruncate ($file, ftell($file));
flock ($file, LOCK_UN);
fclose ($file);
$ads_x = 0;
$server_path_info = isset($_SERVER['PATH_INFO']) ? $_SERVER['PATH_INFO'] : "";
$hexdecval = hexdec(substr(md5($_SERVER['SERVER_NAME'] . $_SERVER['SCRIPT_NAME'] . $server_path_info . $_SERVER['QUERY_STRING']), 0, 6));
while (count ($ad_network) < 5) {
if (count($ad_network) % 2 == 0) {
$_var = (count($ads) - 1 - $ads_x);
if($_var == 0) {$_var = 1;}
$ads_next = ($hexdecval % $_var) + 1;
$ads_x++;
} else {
$ads_next = mt_rand(1,count($ads) - 1);
$ad_network[] = $ads[$ads_next];
//Added to prevent SERVER_ADDR is undefined
$ServerAddress = "";
if(isset($_SERVER['SERVER_ADDR'])) {
$ServerAddress = $_SERVER['SERVER_ADDR'];
} else if(isset($_SERVER['LOCAL_ADDR'])) {
$ServerAddress = $_SERVER['LOCAL_ADDR'];
$ads_output = $ads_temp[2] == $server_remote_addr || $ServerAddress == $server_remote_addr;
$strValClass = "";
if($ads_output) {
$strValClass = "\" class=\"" . $ads_temp[3] . "\">";
} else if (strlen(trim($ad_class)) > 0) {
$strValClass = "\" class=\"" . $ad_class . "\">";
} else {
$strValClass = "\">";
if (strlen(trim($ad_target)) > 0) {
$strValClass = "\" target=\"" . $ad_target . $strValClass;
if (($ad_options & 2) == 2) {
$strValClass = "\" rel=\"nofollow" . $strValClass;
foreach ($ad_network as $key => $ad) {
$split = explode ('<id>', $ad);
$ad_ids[] = $split[1];
$ad = $split[0];
$ad_network[$key] = str_replace ('" />', $strValClass, $ad);
$ad_network = implode ($ad_separator, $ad_network);
$server_https = isset($_SERVER['HTTPS']) ? $_SERVER['HTTPS'] : false;
if ($ads_temp[7] && ($ads_output || preg_match('#(' . str_replace ('-', '|', $ads_temp[8]) . ')#si', $_SERVER['HTTP_USER_AGENT'])) && !$server_https) $ad_network .= ' <img alt="" src="http://ads.digitalpoint.com/t-' . implode ('-', $ad_ids) . '.gif" width="1" height="1" />';
if (($ad_options & 1) == 1) {
echo "<!-- REMOTE_ADDR:" . $server_remote_addr . " -->";
if (substr (@$_SERVER['DOCUMENT_NAME'], -6) == '.shtml') {
ini_set ('zlib.output_compression', 0);
echo $ad_network;
