Bug Wrong datatype for second argument in [path]
Danny
Recieving this error when viewing a members profile
Warning: in_array() [function.in-array]: Wrong datatype for second argument in [path]/dbtech/vbnominate/includes/class_profileblock.php on line 86
I believe there is an error with this function in class_profileblock.php;
			if (in_array($data_data['nomnom_id'], $winner_ids))
Currently uninstalled the product until a solution arises. It seems a simple fix.
I do believe that was hotfixed in the latest version, which was on the third of May, so if you downloaded the product before that grab the files again.
If that don't work here is the manual edits:
Find
Replace with
if (in_array($data_data['nomnom_id'], (array)$winner_ids))
and Find
if (in_array($data_data['nomnom_id'], $nominated_ids))
Replace with
if (in_array($data_data['nomnom_id'], (array)$nominated_ids))
Let me know which solution works.
Find
Replace with
and Find
Replace with
I thought it was something like that. but just wanted to make sure from yourself.
Works fantastically now. Thanks again
When did you download the product?
EDIT: Nevermind I see the updated code in in the lite zip.
Legacy vBNominate
